I have replaced the cowling tilt switch on my s200txrx. Didn't solve the problem. It appears there is no power to the plug where the switch connects. I checked the wires into the plug with a meter and have no power. The throttle tilt works fine.
Cowling tilt switch issue
I had similar problem turned out to be where the tilt system connected to the battery. There was part of the rubber wire covering covering the battery terminal lug. I cut it back reconnected it and no more problems.......yes the throttle switch was working normally through out this entire issue.
Let us know your solution
