Hi
new to outboards, but pretty good mechanically. The engine has gas about a month old, 3/4 tank and the oil reservoir is almost full. Now , when I filled reservoir a few days ago the low oil sensor went off for a few minutes then shut off. This low alarm also went off for a few minutes today before I went out.
My Yamaha 150 had a problem. Today I *****ed slow for about 2 hours. So, I went on cruise for awhile to make sure it wasn't fouled due to driving so slow. Kinda to blow it out. Ran great for 15-20 minutes on plane, then slowed down, drove for another 15 min then slowed down more. I thought it was something causing the limp home to activate and headed home. But it ran great at slow speed and got home. No popping or anything, just slower.
So, I have at least three questions
1) is there a way to determine what is causing the limp home to activate?
2) Is the limp home have a buzzer and it it the same buzzer as the oil sensor? I am just assuming the limp home was activated, but no lights or buzzer went off. BUT it did go off a few months back with no buzzer or lights similarly about a month and a half ago. the mechanic said it was an missing o ring in the fuel filter causing fuel starvation and a leanout. But when that happened it happened immediately when I put the boat in the water for my first time and tried to get it on plane. A bit different now, but seems similar. I do think its fuel problem.
3) what does the limp home do? It seems to me it is somehow shutting down one then two of the carbs, leaving only the third to run home, but I am unsure.
Thanks for any help!
M
All I can think of is maybe the water temperature of the engine (no gauge) or it gets leaned out and engine senses an increase in head temperature OR maybe this low oil sensor goes off. I don't think its a spark problem, b/c it ran smooth all the way home. But I heard no alarm and the oil level gauge on the Yamaha tach was green when this all happened.
M
