2003 F90TLRB is running rough at low speed below 3k rpm. After doing the usual, fuel, plugs, compression check, etc., attempted to sync carbs. The reference carb #4 only draws 9 in Hg max and is not adjustable as far as I know. Setting the other 3 carbs to the same reading smooths the idle out somewhat but there is still an occasional cough while idling and hesitation when advancing to WOT. The manual does not give a spec for vacuum value, only vacuum difference from one carb to the other.
Does anyone know what the normal vacuum reading is for the reference carb?
