Motor ran fine yesterday plus two test runs post replacing the ECM because of a jammed IAC valve.
Went to flush the motor this morning and started fine with higher RPM but after the RPM settled the oil warning light and buzzer came on. Shut the motor down and tried again with the same result. Checked oil level and it is full. Tried once more and lifted RPM the buzzer stopped but the light kept flashing.
Plugged in the diagnostic and nothing showed, did not run the motor though.
