Yamaha f225 txrd low pressure pump not cycling
  • Yamaha f225 txrd low pressure pump not cycling
    The Low press pump runs fine when I jump it directly but does not want to cycle on an off. I do have 12v at the pumps female side.
    Is this a pump control unit problem or ecm problem
    I replaced the low pressure pump and the high pressure pumps, both didnt work wit a direct jump. The engine now runs when I squeeze the fuel bulb and therefore pump fuel into the VST but the low pressure pump will not activate.
    Also what is the pump control units part number if I need to order it?
      first check the 5 amp feed pump fuse.
      the ECU controls the feed pump driver.
      the ECU and driver control the ground path for the pump.
