Hey guys, ive got a 200Hpdi with round gauges, the engine light keeps on flashing(icon 5 in the manual) on the TACH gauge. The maintenance has been done and the maintenance hours were reset. But now im trying to get rid of the engine light flashing. When i press mode for 4seconds nothing happens. Im getting no response out of the gauge. If i single press the mode button it goes from the engine hours to the "0" maintenance hours. But i cant get it to go into the custom mode.
Yamaha 200 HPDI Round Gauge not resetting
Probably need to have computer diagnostic run on engine to make sure it doesn't have a engine fault code, and have gauge checked to see if bad.
are you sure you have command link gauges?
if so, key on engine off, press and hold mode for a minimum of 15 seconds.
any active code will appear.
if 01 or hidden appears that is good.
ÂÂÂÂÂÂ
