Overheat buzzer comes on randomly on one of my twin yr 2000. 150 Yamaha outboard
  • Overheat buzzer comes on randomly on one of my twin yr 2000. 150 Yamaha outboard
    I have installed both overheat sensors on the one engine that over heats. I have used a laser thermometer on each each head. One head was 128°. The other was 138°. I can use the boat all day and not have a problem. Seems like it happens more when boat is idling. Does anybody have any idea what is the problem?
    RE:
    You might want to check the pressure control valve on that motor. They can cause overheat at low rpm if not functioning properly.
    J
      Is the PVC the same as a poppett valve?
        re valve Pressure Control
        Yes same thing. Don't forget to change grommet while your at it as most times it is the problem.
        J.
          PCV or PRV would be my thoughts
