Will my 2002 F115 run with the plug to the IAC disconnected ?
Reasoning - My IAC is not working but is stuck at a level which provides an acceptable idle ie 880RPM. I know this my not be so good if it is cold but I can disengage the gears and life my cold start RPM that way. I'm in the tropics so cold is not a big issue.
Would prefer not to risk burning out that part the the ECU.
Thanks JON
Thanks JON
