I have a 2001 225 OX66 and batteries not charging, actually they are discharging. Put new batteries in and terminal connections are perfect. When started my gauge reads 12 at idle and within a few minutes slowly drops to the low 11's, if I rev to 1500 rpm voltage doesnt increase. If I turn anything on the reading drops below 11 V. The Marina mechanic has looked at it twice and is stymied. I'm thinking the recitifier/regulator may be a candidate for replacement.
The motor runs fine even at full throttle, though the voltage doesnt increase. I measured between the terminals and was reading about .4 V less than my gauge at idle. Normally it has run from 13-14 V. Any ideas
