I have removed all my seals on 2005 Yamaha F90. I noticed on the shifter shaft, has oring and bushing. Is there an o ring under the plate held by two screws? On the prop I have read that both seals has oring facing out towards prop??? Yes or no? Driveshaft seals are the same as prop seals. Do they both face up towards water pump? Yes or no? Thanks
Lower Unit seals
Answered my own questions. The prop seals, both gooves face away from motor.Drive shaft both seals face up away from motor. There is an oring under the plastic cap around shifter shaft.
http://www.boats.net/images/diagrams...NG_DRIVE_1.png
