Water Pressure Gauge.
  • Water Pressure Gauge.
    Any help is greatly appreciated,
    I have a 2003 Yamaha 115 4 stroke TLRB and I want to run a water pressure gauge. Firstly where is the galley plug located at so I can remove it and install the fitting for the line that goes to the gauge? Secondly can I put a T in it and get a sender for water temp, I would like to monitor both. Thanks.
    Here is where water pressure port is,
    No can not put any tee fittings in tubing.
      Thank you I found it last night. That elastration is not the best but I did find it. Ok I would also like to be able to monitor oil pressure and water temp. Any suggestions. Thanks.
