200 HPDI power problems - 2001
  • 200 HPDI power problems - 2001
    Dropped it in the water today and have a power issue. Did all the right winter things, changed the seperator filter, new plugs, drained the VST.
    I'm reading it could be an o2 issue - anyone have any experience ?
    Do I need to take it into a Yama guy ?
    thanks for help
    Start with compression test, have fuel pressure tested.
      O2 sensor feed back is not used above 1500 RPM or so on that engine.
        Thanks for the advice, not to jump the gun, but whats the next step if I have a compression issue
          bad compression = cylinder/piston /ring problem most likely
