1996 40hp back fire
  • 1996 40hp back fire
    I have a 2 cyl 40hp 1996
    backfires and no power SOMETIMES
    Was thinking cdi yamaha dealer says thay don't go bad
    Please any help
    lean sneeze, clean the carbs
      Carbs have been cleaned still sneezing after running in test tank for 10-15mins it starts to backfire
        like I said lean sneeze is my thoughts,
        need to clean better
        some times an ultrasonic bath is needed to get it all
        or you have vacuum leak
        Hopefully you followed steps in service manual to link and sync carbs after reinstalling
        Timing is easy to check with timing light to make sure CDI is setting timing correctly
