I checked my tps sensor last week ,and found that the voltage range went from >49 volt at thottle closed to 3.78 wot. the manual says that it should be .48 to 5.0volts, my referance voltage is 5.0 volts,i tried a new tps and got the same readings, and looking at the tps resistence it is impossible to get 5.0 volts. does any body have any ideas?? thanks
tps sensor
