I was pondering on premixing this engine. I've got everything pretty much figured out except the wiring to the oil tanks.. Not sure of the procedure. Any info would be appreciated. Thanks!!!
2003 vx225tlrb Premix
I believe the motor would last longer. The time from idle to wide open would be lean until the vst caught up, the way I see it. I know that it's a reliable system, but I want to get the best possible longevity out of the motor.I'm not wanting an argument. I would just like to know the procedure..Thanks!!!!!Last edited by Shot1974; 04-11-2013, 05:24 AM.
Bunch of post here how to do it. But essentially, remove pump, replace with block off plate, zip tie float on sender in the up position, plug oil fill hole on VST.1999 Grady Sailfish SX225 OX66
