1987 225hp HELP no sparky no starting
  • 1987 225hp HELP no sparky no starting
    Please help me. I liveaboard a house boat in the Florida Keys, my home and boat have been in the marina yard for 30 days.
    I hoped it would be launched tomorrow HOWEVER I am not getting any spark at the plugs....I did check the obviouse proplems any suggestions???
    Thank you Brian
    Does it have a safety lanyard?
      yes I do and as I had mentioned the obvious has been check. ...thank you for your reply
        did you check the neutral switch in throttle...you should try to bypass it and the lanyard kill.
          Disconnect white wire(ignition stop circuit)from CDI unit, just remove screw and pull wire away from terminal. If it fires with wire disconnected then the problem is in the main wire harness, igniton switch or landyard switch. If no fire then test ignition system on engine, charge coils,pulsor coils, CDI, crank position sensor and ign. coils.
