1999 Yamaha 130HP saltwater trim indicator
  • 1999 Yamaha 130HP saltwater trim indicator
    My trim indicator shows full up with motor down. I have taken the switch off and checked that it is working correctly and it is. how do I adjust to indicate correctly
    Need to test trim sender with ohm meter, should get 580-875 ohms between pink and black wire and 800-1200 ohms between orange and black wires as move lever up and down.
      The older trim senders are mounted with a plastic ring,If that ring cracks it will not be mounted tight and gives false readings when it spins out of the original position. You may want to check that first.
      Joe R
        Dobbo5647
        Thanks guys checked out all mentioned and is now working.
        Cheers from Aussie
