Ok, well this is my first time to play around with a small four stroke outboard. I've had plenty of experience working on snowmobile motors and some two stroke outboard motor exposure.
I have quite a few questions to kick off my motor testing and repairs (if needed).
1) Does a two stroke gas tank line fitting fit on a four stroke
2) Are the gas line fittings brand specific
3) Where can I find the model on the motor, all I see now is it's a 9.9hp
4) What should be examined before I even attempt to start it.
5) How can I determine the battery cable polarity hook-ups
I'd really appreciate any help the forum members might be able to give me on getting this motor up and running. Who knows it might not need much. The motor doesn't seem very "old"
If I crack the throttle is will rev up a bit then hesitate a bit, cough and die. at least once or twice, I thought I heard a back fire through the carb before it died. It seems to smoke more than I would think that a 4 stroke should too.
