I have been trying to fix a leak in the lower unit for a 1994 150 HP. Water has been contaminationg the oil.
I replaced the seals and O-ring at the input shaft and I also replaced the prop shaft seals. I installed the seals per the manual.
A pressure test indicates the prop shaft seals are leaking.
Any suggestions?
Any suggestions?
