Test of oil pressure switch
  • Test of oil pressure switch
    I bought a used yamaha 2006 F90TLR.
    I want to verify that the sensors and audible alarms work for both the oil and temp.
    Any suggestions?
    Yamaha Service manual for that motor is the only thought I have, should give where and what to hook up to test everything, and the specs
      Would need special test harness's on that engine to test, best to take to a dealer to have tested.
      Can test buzzer by pulling landyard cord and crank engine over, buzzer should sound.
        go to radio shack.
        buy a pkg of 220 ohm resistors.
        unplug the temp sensor,plug in the resistor.
        start the engine, alarm should sound in less than 90 seconds.
        there is a built in delay.
        to test oil switch, short the pink to ground alarm may delay if engine speed is lower than 2000 RPM and engine temp is less than 113*F.
        simply increase the RPM above about 2000 and it will work.
