2012 F150 from 2001 F115 repower
  • 2012 F150 from 2001 F115 repower
    Manufacturer: Yamaha
    Year: 2011
    Model: F150
    Serial: 63pl-1120333
    Component: wire harness adaptor
    Message:
    I repowered my boat; 2001 F115 to 2012 F 150. The connections were easy except for the wiring.
    Is there a wire harness adapter that will connect the new motor to the existing 2001 wire harness @ the motor end? The ends aren't matching up.
    The existing gauges are Yamaha Pro Series II digital gauges.
    old motor details F115TLRZ 68VL305579 07/00
    new motor details F150LA 63PL-1120333 05/12
    yes there is.
    boats.net will be able to assist with a part number for the trim/warning adapter.
    I dont do part numbers from home .
      OK - thanks for the info. I started @ boats.net, and the response was go to the yamaha parts forum. Thanks for helping me out. I'll call (vs Email) and see what happens.
      Thanks again
      Kevin
        You can wait to see if they respond here, but if you are in a hurry, then call
          I'm on the phone now - 1st person can't find the part.
          2nd person gave up.
          I'll call tomorrow and ask for Davis.
          Called on Saturday - was offered a $500 wire harness (?).
          I'll try calling on Monday.
          Last edited by kjfisherman; 03-17-2013, 07:22 PM. Reason: phone call details - this has been a tough part to specify.
            the moderator on this site, boats.net, can answer it.
            you can contact him/her through this website.
              Yes would need 6Y5-85335-00-00 Adapter Harness, -82 gauge to 2005 and newer motor, install at tach.
                harness adaptor
                Thanks - I'm ordering the harness adaptor today.
                Kevin
                4/11/13
                The harness was easy to install and worked perfectly. Thank you very much for providing a part #.
                Kevin
