1993 Yamaha ProV 150 water in gear case
  • 1993 Yamaha ProV 150 water in gear case
    the lower unit gear case had water in it. What parts do I need to make the repair?
    the ones that are leaking.
    could be driveshaft seals or housing oring.
    shift shaft seal or carrier oring.
    propshaft seal or carrier oring.
    could be bad drain and vent gaskets.
      water in gear box
      Thanks rodbolt 17
