F115 Four Stroke analog tach
  • F115 Four Stroke analog tach
    Have a 2005 F115 and orange and black analog tach withOil and temp warning lights. When motor was put on the boat the warning lights were not hooked up see attached photo, What wiring harness do I need to hook thes idiot lights up and make them functional?
    Thanks Snowgo666
    would need the part number of the tach.
    not all analog tachs can use the 4 stroke warning system.
    if the tach actually has a 2 or 4 stroke selector switch it should work with a simple trim/oil warning harness.
      Trim/oil harness is part number 6Y5-83653-20-00 23 ft Trim/Oil harness other lengths available. Connects to engine and to Tach.
        reply
        Gentlemen
        Thanks for your help
          It is a black pro series Yamaha analog tach . I have read other posts that a 68F-82553-xx-00 harness would work would either one work?
            Deleted ad!!!
            What the hell?
              Originally posted by Yamaha Outboard Motor
              Thanks for contributing.
              Very poor taste.
                Follow on question
                Trim and oil harness 6Y5-83653-00-00 is like $40
                2004 and Prior Trim and oil Harness 68F-82553-50-00 is like $138
                What is the deal here? My motor is 2004 with Pro series orange and black face Tach
                  Do you all realize you help that person advertize by quoting his post.
                  Best thing to do is just click on the report icon at the top right corner of the post to report the post and they will remove and block him.
                  Your quotes just make it harder for them to remove it all
                    Done thanks
                    Snowgo666
                      Already did in his other post earlier today..Same thing
                      Needless to say, I wouldn't buy jack from him!
                        As you can see they removed his post, but when you quoted him your post still advertizes his junk.
                        You can edit your posts to remove his stuff or delete
                        Sorry but I can not help with why the cost of harness is what it is
