Oil reservoir does not fill
  • Oil reservoir does not fill
    Hi Rodbolt it's me again with another problem, my yamaha z200 hpdi 2 stroke now does not fill two stroke oil into the reservoir on the motor, but if you flick the switch next to the reservoir it fills up with oil, is there a pump inside the main oil tank? What do you suggest, thanks
    do some searching on the problem, he has covered trouble shooting it many times
    not sure if it would be the same as your motor or not but here is a thread on oil a problem like yours
    http://www.yamahaoutboardparts.com/f...html#post78528
      the Z oil transfer system is identical to the OX66 system.
