Have a question about selecting the mode (trip or engine hours) on this gauge. Does the engine have to be running before the you can select trip or engine hours on the display? I can't get it switch modes on the boat nor can I get to work on in the shop connected to 12v.
Trim works, tach works, light works, but the mode switch seems to just turn the hour meter off and on. Can't find a combination that will allow me to select trip or engine hours.
The gauge is 6Y5-8350T-91
Engine is a 2005 F90TLRD
Boat had a wiring harness from a 2004 (2 plugs) each end so I am using just one plug on each end.
Just want to rule out the slight possibility of an issue with the wiring harness before I return the tach.....
