My (Australian) 1997 Yamaha C60TLRV (60HP two stroke CV) began running roughly & erratically at idle. Within 30 seconds, it splutters itself to a stop. At this stage, it runs above idle OK.
It states on the side of the CDI unit, if engine stops or runs erratically, try disconnecting the emergency return to harbour wire loop. On doing so, the exhaust note of the engines does change however it will now run smooth & does not stop.
Three questions:
1. is it reasonable to assume the CDI is at fault;
2. could one assume the C60TLRV USA CDI is compatible with my Australian model?;
3. do Boats.net ship to Australia?
The numbers on my CDI are: 6H2 10 CU7385. Part numbers on the USA updated CDI are 6H2-85540-13-00; updated from 6H2-85540-10-00.
thanks for advice
Paul
Three questions:
thanks for advice
Paul
