Hi Guys...First post here and we need some help. We are based in Port Blair Indian Andaman & Nicobar Islands. It's a pretty remote place and we need to be self sufficient. We normally cope well with engine sevicing and breakdowns, but this ones got us stumped. Below is a brief background the engine it is a 2003/4 F225 Yamaha
About one month ago we were not getting the full rpm out of the engine it was maxing out at 4300 rpm whereas prior to this max rpm was 5400 rpm
Also when starting the engine it would high idle around 1200 rpm this would then slowly reduce to 600-700 rpm.
On shifting into gear the rpms would drop and the engine would miss and almost stall unless the throttle was increased, once increased the engine would run normally through the rev range but not go beyond 4300 rpm.
About 4 days ago it stalled and would not start, our local mechanic has done the following:
· Adjusted the throttle sync screws
· Adjusted the tps voltage
. Checked Thermostats
· We have replaced plugs, there was carbon fouling but acceptable, one plug had some oil on it
· We have checked the fuel lines
The engine will not start unless it is given some throttle and if it does start it is missing and idling high, there was also some backfiring on trying to start the engine at times.
More adjustment has been done to the above and as of now
· It does not self start
· If helped then it is idling at 2500 rpm
· It is not missing at 2500 rpm
Attached yds data sheets and comparison (to follow cannot upload exel) with the other engine which is in running condition.
Any help you can give us will be of much help as we are quite stuck here with no special tools at hand.
Thanks and looking forward to your responses
( Having a challenge loading the exel diagnostic sheets will post PDF shortly)
