Can anyone help, I have 2002 F115 that has so far run faultlessly, however it now leaking oil ( although at the correct level ) when the engine is tilted, the oil also alarm sounds when first started after the motor is down, then on restart the alarm is off, I understand that there may be an issue with the oil pump seal and the power unit may have to be lifted but before pay someone to do it I need to confirm this is in fact the issue, any comments would be most welcome.
Thanks.
Thanks.
