Well, I'm an idiot. I was doing my routine annual compression test. Normally I was doing it at normal throttle. I figured it was better to do it at WOT. Compression was great across the board.
BUT....when I went to start it I forgot to connect throttle and set back to idle and it revved to the moon. I tried to shut it off as quickly as possible but it was nasty. When I started it up it idles but fights to run above 1500 and misses. Running perfect before this.
Did a reed valve let go? What would be hurt revving very high in neutral?
I re-did the compression test and it's the same as it was.
It's an 89 200hp
RODBOLT, please help!
It's an 89 200hp
