fuel management does not work
  • fuel management does not work
    Hi there ,
    My Yamaha fuel management does not work anymore . The gauge still displays everything except the fuel burn which makes the sensor suspicious ..
    Is there any way how I can test either the sensor or the gauge ?
    I checked the 3 wiress going from the sensor to the gauge and they are all ok .
    I checked the screen of the sensor it was not blocked .
    I blew through the sensor and can hear very well the paddle wheel spinning .
    Any more ideas ?
    Before I place an order I want to make sure to order the right thing ..
    Thanks in advance !
    Jürgen
    When you blow through it should see a reading on gauge as paddle wheel turns, if not may be bad sensor or wiring.
      When I blow through and the wheel spins I do not get a reading on the gauge .
      The 3 wires I have checked from the sensor to the gauge - all good .
      Is there no methode to test the sensor independently from the gauge ?
      Cheers !
        There is no test procedures in manuals for it, check continuity on wires in harness, if ok replace sensor.
