C40PLRS
'94 year, 2 cylinder, 2 stroke.
I ran it on the earmuffs in the yard. Idle is good. (no tach so not sure RPM but it sounds good)
Works good coming out of neutral into forward and advancing throttle.
If I take the throttle up pretty high and then slowly start returning towards Idle, it will try to die. Sometimes while it's still pretty fast, sometimes closer to slow speed, sometimes it doesn't do it. Advancing the throttle usually fixes it. If I don't advance the throttle, it will die all the way.
After it does die, I can put it in neutral and it fires right up, real easy.
The tank is almost empty, (maybe an inch or so) but it's fresh.
It has new plugs but I haven't checked to see if they are the right ones.
They were in it when I bought the motor.
Haven't had it in the water yet.
Ideas?
My plan was to put it in the water and see if it still behaves that way.
Jim
Ideas?
Jim
