Hi, I have a Yamaha F70 2012 4-stroke. It works fine but when it reaches its working temperature and I put it on neutral, the RPM stays at 2,000. I just need to turn it off and start it again and "youpi!" the RPM is in the 750-800 range. At the morning start-up, everything's fine too. This problem is encounter only after a run, I put it to neutral and want to enjoy the scenery and the engine is running and running fast (2,000 rpm)... It's annoying and I'm afraid to break something everytime I need to engage in drive or reverse (I can hear a poock and the boat swing a bit). Don't know if I can do something about it??
Thank you for your answer!
Francois.
Francois.
