I have a 2005 115 4 stroke. It will not turn off with the key, traded control box and still will not. Also has a higher speed skip, checked fuel and vacuem and it appears ok. Could it be electrical as well and linked with the ignition not turning off ?
f115 4 stroke not turning off
I have a 2005 F90 and am on my third ignition switch due to the same won't shut off problem. The quick solution is to choke it out. Mine started when I bumped the starter and the boat was on the trailer. I panicked and after about 10 seconds remembered the choke. The switch is available on Amazon.com and costs about $115. There are so many places on-line to buy these ignition switches that it must be a common failure item. The change out is very simple and takes about 10 minutes. Its just a matter of unplugging the existing switch under the dash and plugging the new one in. Got to be a design flaw in the switch.
FLCoyote
ÂÂ
