1997 Yamaha 225 Tilt & Trim Hyd. system. Is there a flow chart for the Hyd. system on the internal block where the check valves are. Looking how the Hyd. flowes throw the different channels as they go through the valve system from the resorvior to the trim pistons then to the tilt piston. As well as when they are lowered. Please advise where one might go to get this info.
225 Trim Tilt
