I have an issue that when I advance throttle there is a bogg and sputter with very low power. if i back off the throttle and hit it hard again it may or may not take off as usual. sometimes I need to start from no throttle a few times before a smoth transition in rpm can happen. Once I get threw this rough spot engine runs great under load, also idles fine. It is only the transition to get on plane.I have cleaned my vst filter, and checked fuel pressure both at idle and under a load (when engine is bogging. 35 to 38 pounds. I have also cleand and tested the 0/2 sensor. fuel filters and lines are all new and un restricted. I have not done a vacume check (not sure how) however I am under the impression if the fuel pressure can maintain 35 pounds then it seems fuel starvation can be ruled out. I am a bit suspect of the throttle possition sensor. Can someone direct me to a tps test so I can rull that out.
It is tuna time here in northern Ca, I have missed two good runs already and i sure would like some tips.
Engine model. S250TXRW salt water series 250 hp 2 stroke fuel injected (not high pressure injection)
