I have twin 200 hp - 2003 Yamaha outboard motors.
Issue:
My remote oil pump will not turn on to pump oil from the remote oil tank to fill the outboard primary oil tank.
The alarms work correctly.
The RPM dropped to safety RPM Correctly.
The emergency Toggle switch that is located on the motor turns on the pump and fills the primary oil tank from the Remote Tank. Its tough taking the engine cover off in rough seas and hitting the emergency toggle switch -
Question:
Which components should I check or replace that tells the remote oil pump to kick on when the primary tank is at low mark?
Issue:
Question:
tems out.
