I was crusing along at full throttle when the rpm's dropped to about half of what they should be. Runs fine below half throttle, starts fine, fuel flow is good, throttle linkage does open up all the way. The motor sounds like it's trying to go but something is holding it back. Is the C.D.I. unit going bad? Any other ideas as to what the problem could be? Thanks for any help!!!
1997 Yamaha C40 will only run at half throttle.
