Digital Gauge
  • Digital Gauge
    I have a 6Y5-8350T-00-00 it has 12v going to it but has no display unit does not come on. Is it dead? Thanks
    Do you have ground running to it as well?
      Yes, I have 12volts at the gauge.
        are you checking the voltage at the yellow wire bullet connector to the black bullet connector with the key on ?
          Yes the key is on the voltage was measured at the terminals with gauge connected and disconnected.
            Well if you are sure it has proper voltage to the meter and a good ground also, then it sounds like gauge is dead
