I have a 1989 Yamaha 90 Outboard that I'm trying to figure out. I recently replaced the forward gear in the lower unit and got everything back together, the problem is when I install the lower unit I either get one gear and that's it. Does the lower unit have to be in gear to install it properly or something? Thanks
Lower Unit Installation
Originally posted by Sequoiha View Postjust make sure the lower unit is in neutral, and the control handle is in neutral, should work fine.
Put both the lower unit and control box in reverse. As you trying to install the lower unit (while in reverse) turn the propeller (either direction, be sure to line up the water tube and shift shaft) should eventually slide into place.
Originally posted by boats.net View PostPut both the lower unit and control box in reverse. As you trying to install the lower unit (while in reverse) turn the propeller (either direction, be sure to line up the water tube and shift shaft) should eventually slide into place.
ÂÂÂÂÂÂÂ
