I have a 1993 30 hp with oil injection, I want to remove the oil injection. If the sensor is removed from the circuit will the motor run at all throttle speeds, or will I have rpm and power problems. What has to be done to remove the sensor from the motor?
REMOVAL OF OIL INJECTION FROM 30 HP
