Good Evening -
I went out to the boat yesterday and both my batteries were dead. Battery switch was on, but nothing on the panel was switched on.
So first issue, I'm guessing I have a short somewhere. Not a big deal if I remember to switch off the batteries when I leave, but not great news. Also, as far as I know, not easy to trace.
Second issue, I charged the starting battery, and it only went up to about 12.2 volts. I brought it down to the boat hoping I could start her up and use the engine to charge the house battery. She didn't crank so I brought the other battery home in hopes that BOTH will start it tomorrow.
The batteries are both about 5 years old so I'm assuming they just need to be replaced. While charging, neither of them are showing bubbles in the water holes. Is that a sign they aren't taking a full charge?
I'd also like to check the alternator just to rule that out as an problem. If I get the charger on the alternator, what should the output be from the alternator be? And If I remember correct, the positive lead of the multimeter goes on the alternator and the negative goes to ground...correct?
I realize this is rambling with a lot of questions, but thanks
-Chill
-Chill
