Hi,
I need help. Bought a rebuilt motor and am having issues. Oil would not pump from main tank to engine, was told most likely the wire harness(13yrs old). Replaced the harness from tank to engine - no help. Looked at the forum and found to test remote tank pump motor, tested it and it was working fine.
Went to engine oil tank and found that the level guage had wire ties holding the floats in the up position! Took off wire ties and cleaned out remote tank. Removed all the oil in remote tank and turned the key on and the alarm went on and the tank started to fill up, it got to the first level(hash mark) and still continued to fill all the way to the top hash mark and stopped, but the alarm still stayed on?? I was told to turn off key and wait 15 sec for unit to reset did that and the alarm still came on when I turned the key on.
What can I do next? Could a bad float switch cause the alarm to go continuously?? Key switch?? Help!!
Thanks-
Mark
Thanks-
Mark
