Hi there all. I Have been working on installing pro series tach./temp, trim and fuel gauges. The way I have them hooked up right now I have lights in all gauges and the tach and trim gauges work. I still have three wires on the back of the fuel gauge that are not hooked to anything and I have not connected up to the tank. The wires are two black (ground) wires and a yellow wire. I am assuming that the yellow wire should be hooked to sender wire from tank which is red and that one black wire is to go to ground and that the other black wire is to hook to another gauge in series if there was one.
My questions are: 1. am I on the right track with the wires ?
2. can I ground the tank to the second black wire since I have no more gauges and the other two are already grounded or do I have to ground the tank elsewhere?
Anyone able to set me straight, I'm so close!
