Hi All,
I decided to check the internal diodes on my 2002 115 XTRA. This required me to remove the heads. Upon opening, I noticed some corrosion in the heads , that I scraped off with a flat head screwdriver. I cleaned out all of that gunk and any I can get to in the water jackets in the power head.
I have the gaskets, but still have some items to address.
1. I still have some gasket residue. How do I remove the gasket material and/or any corrosion that is sitting on the gasket surface? I have read 400 grit sandpaper, but want to know what is the best option.
2. I read not to use any kind of gasket sealer, but to use anti sieze on the bolts. Any particular kind?
3. What is the torque settings for the head bolts?
Any tips/insights is greatly appreciated.
