Hello, I have a lanyard that does not work as it should. The lanyard switch doesn't need the insert for the outboard to run. I took a look and it appears one of the wires is not hooked up from the lanyard sw. I think I may have found where the wire plugs in at. My question is " will the motor still turn over if I found the correct wire ?" I am a little surprised that with one wire off the switch that it would still run.
Drew
Drew
