I have a 2006 Yamaha f150 4stroke with 150 hours on it and the gas gauge always reads full. I replaced the sending unit and it still reads full. All the other digital gauges work. Any ideas?
F150 gas guage won't work
Don't know what gauges you have.
Remove sender from tank and check that it will read all ranges.
The pink wire from speedo should be connected to pink wire from fuel tank sender and black to black, check settings in speedo are set for ABYC US sender.
May still be wired up wrong or bad or mismatched fuel sender.
Â
