Hi all,
on my last outing when i started the outboard it was blowing blue smoke for 30 seconds then dissapeared. Later in the day Ihad the same thing after the motor sat there for a while.
Its been a month since I have used it( away with work) and started it today for the same result.
The motor is a 08 with under 200hrs. Oil level is 2/3 full. I can see no visiable oil leak but can only assume there is a weep somewhere in the motor internally.
THe motor is stored in the trim down position due to my driveway angle and not wanting water to pool into the rear of the topcowl.
Has any one else had a problem. The motor runs normal and no weird sounds etc.
I appreciate any info you can provide.
Was about to head up the coast and fish for the next few days but think its dealer time.
regards
Aaron
regards
Aaron
