I own a 2002 Yamaha T9.9ELRA High Thrust motor. I purchased this motor used and was told that it came off a sail boat. It came with the "standard issue" high thrust prop. (I believe it was a 11 3/4 x 9 1/4 or something very close to that.)
I purchased this motor to use on my new G3 Eagle 165 on 10hp limit lakes in the area. With the original prop I was only able to turn 2200 rpm at WOT, not sure if that is normal or not for a high thrust with that prop, and got about 7-8 mph by GPS.
In an effort to get the motor to it's WOT rpm range of 5500 rmp I replaced the original prop with a "normal" small engine prop, a 9 x 9 3/4, as a test. I am now able to turn about 2500-2600 rpm at WOT and get about 7-7.5 mph by GPS. I have considered going to about a 7 pitch in an effort to further increase my rpm and put less stress on the motor. My only concern is that I will most likely lose even more speed due to the low gear reduction and lower pitch. Can anyone give me any advice on using these high thrust motors on smaller boats? I knew it would not be fast, but I don't want to hurt the engine by running it at low rpm while at WOT.
My last ditch effort to remedy all this is to find a standard long shaft lower unit and swap it with the high thrust lower unit to get back to the higher gear reduction. I don't know of any way to determine what the interchange possibilities of this are. Does anyone know if the standard long shaft 9.9 lower units will interchange with the high thrust lower units? I really think that I would be happier with the standard gear reduction for this boat. My loaded tournament weight is less that 1500 lbs total.
Any help or suggestions would be greatly appreciated. Thanks.
Malvin
Malvin
