Great forum and great information here. I am a long-time customer of boats.net.
I wanted to make this post to confirm I am on the right track. I have a sailboat with twin T9.9 four-stroke engines, both year 1995. They are fueled from a single 27 gallon Tempo plastic TP27S tank (no baffles as far as I know), tank is also 17 years old. Al hoses are 1/4 inch I.D. The configuration is: Tank --> hose --> Racor filter/water-seperator --> hose --> t-connector --> 2 hoses, one to each engine.
In the run from the t-connector, to each engine, it is: t-connector --> hose --> bulb --> hose --> connection to engine
This year, I have been having problems with them dying unexpectedly. I'd warm them up, go out and sometime during the trip, an engine would die. I would need to pump the bulb to get fuel back into the line, then it would be OK. But it might die again later. This was happening to both engines, but not at the same time.
First thought was an air leak in the lines. I changed the entire run of gas lines from the tank to the engines. This did not help. But I now have new gas lines, which is good!
I checked the tank vent. It is fine.
After a frustrating day on Sunday with this problem (really rough out there) and massive trouble-shooting effort yesterday, here is what know:
- Sitting in the harbor, if I disconnect the fuel hose from the engine and use the bulb to pump fuel into a large, clear container, it flows regularly, with no problem. This tells me that the fuel flow from tank to bulb is OK when calm.
- Sitting in the harbor, I ran both engines in neutral for 30 minutes at varying RPMs 2000-2800. Nothing died. This tells me that fuel flow all the way from tank to engine is OK when calm, and it tells me that the fuel pumps on the engine are probably OK.
- There was a little water in the separator before I started the trouble-shooting yesterday, there was none there after running the engines for 30 minutes in a calm harbor. The filter does not have crud in it.
From all this, here are my conclusions:
- This problem only manifests itself when the boat is bouncing around on the water
- filter - working ok
- lines - ok
- engines - working ok
- fuel coming from tank when calm - good and clean
- fuel coming from tank when tank is sloshing around - NOT OK
One more piece of information - my tank is now about 1/4 full.
My feeling is that the problem is caused by one or more of the following:
- water may be in the tank and it gets ingested when the fuel sloshes around
- foreign matter may be in the tank that somehow blocks the pickup hose momentarily when the fuel sloshes around
- the pickup hose may not be sitting in pure fuel, for some reason, and it is sometimes sucking air when the fuel sloshes around
What do you experts think of my analysis and conclusions?
Next step is to fix the problem , but I wanted confirmation I am on the right track.
- lines - ok
