captdenbrown
  • captdenbrown
    70 hp 2 cycle motor needs fuel sprayed in cynlanders for it to start and once starter will not idle.
    New plugs,water seperater filter and fresh gas
    Pull and clean carbs properly and then do the link and sync like service manual says after reinstalling.
    It would be a good idea to clean/flush lines and pump before hooking back up to clean carbs just to make sure you do not dump more trash into the cleaned carbs.
